Create a Kubernetes file in the templates directory. Use the variables defined in values.yaml and _helpers.tpl. In this example, rc is replaced with deployment, and the shared storage mounted with ISCSI is replaced with pvc.
If the Helm package contains the NodePort service, you must specify a NodePort number and make sure it does not conflict with the existing port numbers. As a best practice, specify a NodePort number from 30000 to 32767. |
xwiki-deployment.yaml
apiVersion:apps/v1beta2
kind:Deployment
metadata:
name:{{ .Values.name }}
labels:
app:{{ .Values.appName }}
chart:{{ template "chartName" . }}
release:{{ .Release.Name }}
heritage:{{ .Release.Service }}
spec:
replicas:{{ .Values.replicasCount }}
selector:
matchLabels:
template:
metadata:
labels:
spec:
containers:
- name:{{ .Values.containerName }}
image:"{{ .Values.image.repository }}:{{ .Values.image.tag }}"
imagePullPolicy:{{ .Values.image.pullPolicy }}
env:
{{toYaml .Values.env | indent 12}}
ports:
- containerPort:21260
resources:
{{toYaml .Values.resources | indent 12}}
volumeMounts:
- mountPath:/etc/localtime
- mountPath:/usr/local/xwiki
securityContext:
privileged:true
nodeSelector:
{{toYaml .Values.nodeSelector | indent 8}}
volumes:
- name:time
hostPath:
path:/etc/localtime
- name:devopscloud-xwiki-data
persistentVolumeClaim:
claimName:{{ .Values.pvc.data.name }}
terminationGracePeriodSeconds:5
xwiki-service.yaml
apiVersion:v1
kind:Service
metadata:
name:{{ .Values.serviceName }}
labels:
spec:
type:{{ .Values.service.type }}
ports: # The name key value of the ports cannot exceed 15 characters.
{{toYaml .Values.ports | indent 2}}
selector:
xwiki-data-pvc.yaml
apiVersion:v1
kind:PersistentVolumeClaim
metadata:
name:{{ .Values.pvc.data.name }}
labels:
spec:
accessModes:
- ReadWriteOnce
resources:
requests:
storage:{{ .Values.pvc.data.size | quote}}
xwiki-configmap.yaml
apiVersion: v1
kind: ConfigMap
metadata:
name: {{.Values.name}}-version-{{.Values.version}} # To display this setting in configuration management, place "-version-" between the name and version.
namespace: {{ .Release.Namespace }}
annotations:
cm-name: {{.Values.name}} # To display this setting in configuration management, specify this parameter.
labels:
app: {{.Values.appName}}
chart: {{template"chartName".}}
heritage: {{ .Release.Service }}
release: {{ .Release.Name }}
data:
demo: demo
The following Kubernetes resource objects are supported in the current version: Deployment, StatefulSet, Service, Secret, and ConfigMap. |
