To use the console to access the cloud hosts running on a CAS compute node managed via HTTPS, make sure VNC proxy for the cloud hosts is disabled on the CAS compute node. |
On the top navigation bar, click Cloud Services, and then select Cloud Hosts from the Compute menu.
If a system-generated password is used for cloud host access, click the name of the target cloud host, and then click the
icon in the Basic Info are to obtain the password.
Figure-1 Viewing the system-generated password
Return to the cloud host list, and click Console for the target cloud host.
Enter the password to access the operating system of the cloud host.
To use this method, make sure the local PC can reach the cloud host network.
At the first login through MSTSC, you must first enable remote connection for the cloud host. This section takes the first login as an example. At subsequent logins, you can start from step 4.
To access a cloud host through MSTSC:
Access the console of the cloud host. For more information, see "Access through the console."
Open the Start menu, click Control Panel. Then, click System and click Remote Settings.
Click the Remote tab, select Allow Remote Assistance connections to this computer, and then click OK.
