Key authentication is available only for Linux cloud hosts. For more information about key authentication, see "Access by using the SSH key." |
From the left navigation pane, select Key Pairs.
Click Create.
Figure-1 Creating a key pair
Specify the key pair name and creation method. If you use an existing public key, specify the public key information.
Click OK.
Table-1 Creating a key pair
Parameter |
Name |
Specify the key pair name. |
Creation Method |
Specify the creation method.
