Be cautious when you delete a DNAT rule. After you delete a DNAT rule, external users will be unable to obtain the cloud host or load balancer services from the public IP address in the rule. |
On the top navigation bar, click Cloud Services, and then select NAT Gateway from the Network menu.
Select one or multiple DNAT rules, and then click Delete on top of the rule list. To delete one rule, you can also click Delete in the Actions column for that rule.
