Configure the root organization
  1. On the top navigation bar, click System.
  1. From the left navigation pane, select Organization Management.
  1. Click the Quotas tab.
  1. Click Edit.
  1. Select one or more AZs. The AZ names become blue after you select them.
  1. Select a quota template from the Quota Template list, or click Manage to create a new quota template.
The system provides the following quota templates:
  1. To add a network segment for classic networks, click Add IP Segment.
The IPv4 segments that can be used by classic networks must be added here.
Table-1 Configuring network segment parameters
Parameter
CIDR
Specify a network segment in the CIDR format. The IPv4 segments that can be used by classic networks must be added here. As a best practice, do not add 10.0.0.0/8, 172.16.0.0/12, and 192.168.0.0/16 that are used by VPCs.
Address Pool
Specify IP address ranges in the segment. You can specify multiple address pools.
  1. Click OK.
