After a host enters maintenance mode, you can shut down, restart, and wake up the host. After you perform these operations, the host is still in maintenance mode. To enable the host to run correctly, configure the host to exit maintenance mode.
Make sure no running or suspended cloud hosts exist on the host.
On the top navigation bar, click Resources.
From the left navigation pane, select Virtualization.
Click the Expand icon
on the left of CloudOS, and then click the Expand icon
on the left of a cluster.
Click the name of a host.
Click Enter Maintenance Mode.
Select Automatically migrate running or suspended cloud hosts to another host or Automatically migrate shutdown cloud hosts to another host, and then click OK.
Click Exit Maintenance Mode.
