On the top navigation bar, click Resources.
From the left navigation pane, select Virtualization.
Click the Expand icon
on the left of CloudOS, and then click the Expand icon
on the left of a cluster.
Click the name of a host.
Click the Advanced Settings tab.
Click the NUMA/CPU tab.
Parameter |
CPU |
The number of NUMA nodes equals the number of physical CPUs on the host. The number of CPUs on a NUMA node equals the number of CPU cores (multiply the superscalar value if supported) of each CPU. The NUMA nodes are numbered from 0. Each NUMA node contains CPU, I/O bus, and memory resources. |
State |
State of the physical CPU.
Bound vCPUs |
Number of virtual CPUs bound to the physical CPU. |
Cloud Host |
