Delete an image
  1. On the top navigation bar, click Cloud Services, and then select Images from the Compute menu.
  1. On the Images menu, to delete a single image, click Delete for the image. To delete multiple images, select the images, and then click the Delete button.
  1. In the dialog box that opens, click OK.
You cannot delete an image that is being used by cloud hosts.
