Before you create an image source VM or course, you can upload required software to a shared directory on a cloud host. When you are creating the image source VM or course, you can mount the shared disk to install the software.
From the left navigation pane, select Images.
Click the Shared Softwares tab.
Click Upload Files.
Click Upload. Select the target file or software package. The system will automatically upload the file or software package and display it in the uploaded file list.
Click Close.
Download or delete the uploaded files and software packages as needed.
· Software sharing is available for VDI, IDV, and VOI image source VMs, and VDI and VOI courses. For image source VMs with Linux installed, software sharing is available only for VDI image source VMs. · Before you create a course, upload the H3C_Learningspace_App-version-win32.zip package and required software to the shared disk. · You can create subfolders under the default software sharing path and upload files and software packages to any folder. · File sharing supports bulk file upload, breakpoint continuous transmission, and file filtering by username or upload operator. |
