Perform this task to edit, delete, and download IDV desktop images. ARM hosts do not support IDV desktop images in current software version.
From the left navigation pane, select Images.
Click the Desktop Images tab.
Click Edit in the Actions column for the IDV desktop image to be edited.
In the dialog box that opens, edit the settings as needed, and then click OK.
Click Delete in the Actions column for the IDV desktop image to be edited.
Click OK in the confirmation dialog box that opens.
Click Download in the Actions column for the IDV desktop image to be downloaded to start downloading the desktop image.
The desktop image is downloaded to the path set for the browser. |
For migration to succeed, do no migrate an image that is being edited or downloaded. |
Click More in the Actions column for the desktop image to be migrated. From the dropdown menu, select Migrate.
In the dialog box that opens, select the migration destination address, click OK.
Destination Address: Destination IP address of the desktop image migration.
