Manage disk pools
Edit a disk pool
You can configure the cache mode for a block storage disk pool only when you create the disk pool.
  1. From the navigation pane, select ONEStor > Resource Management.
  1. Select Disk Pools.
  1. Click Edit in the Actions column for a disk pool.
  1. Edit the disk pool parameters.
  1. Click OK.
Delete a disk pool
You cannot delete a disk pool when it is in use.
  1. Click Delete in the Actions column for a disk pool.
  1. In the dialog box that opens, click OK.
View disk pool details
  1. Click Details in the Actions column for a disk pool.
