Manage system images
This task allows you to download, edit, or delete a system image.
Download a system image
  1. From the left navigation pane, select Images.
  1. Click the System Images tab.
  1. Click Download in the Actions column to download a system image.
  1. Click OK.
Edit a system image
  1. Click Edit in the Actions column to edit a system image.
  1. Enter a new image name, and click OK.
Delete a system image
  1. Click Delete in the Actions column to delete a system image.
  1. In the dialog box that opens, click OK.
