Configure shared file systems
About shared file systems
In a physical environment, a LUN is directly mounted to a physical host. After you format the LUN to FAT32, NTFS, or EXT2/3/4 file system, the host can access the LUN as files.
In a virtualization environment, a LUN is shared by multiple hosts. To avoid resource conflicts, you must format a LUN to a shared file system, OCFS2, for example.
The system supports iSCSI shared file systems and FC shared file systems.
A shared file system can be shared only by hosts inside a cluster.
Configuration workflow
  1. Add a shared file system—Add an iSCSI or FC shared file system.
  1. Configure shared storage—Add shared storage for a cluster based on an iSCSI or FC shared file system. For more information, see "Add shared storage."
  1. Manage shared file systems.
  1. From the left navigation pane, select Data Center > Virtualization > Cluster name.
  1. Click the Shared File Systems tab.
  1. Click Add.
  1. Configure the basic parameters, and then click Next.
  1. Configure the LUN parameters, and then click OK.
Edit a shared file system
  1. Click Edit for a shared file system.
  1. Edit the parameters as described in "Parameters," and then click OK.
Delete a shared file system
  1. Click Delete for a shared file system.
  1. Click OK.
Format a shared file system
Formatting a shared file system causes data loss on disks. Please make sure you are fully aware of the impacts of this task.
  1. Click Format for a shared file system.
  1. Click OK.
