Perform this task to view console information, such as VM UUID, VNC port, MAC address, and IP address, for a VM. You can access a VM on a Webpage or through desk.rdp.
Before accessing the Web console, do the following:
Make sure the browser version meets the requirements. As a best practice, use Chrome39, Firefox19.0, or higher versions.
Make sure VNC proxy is enabled and the IP address of Space Console is configured as the proxy server address if the login method is HTTPS. For more information about VNC proxy, see "Edit a VM." For more information about VNC proxy server configuration, see "Configure advanced parameters."
Before accessing a VM through desk.rdp, enable the VM to support remote session.
From the left navigation pane, select Data Center >Virtualization > Cluster name > Host name > VM name.
Click the Console tab.
To access the VM on a Webpage, click Webpage.
To access the VM through remote desktop, click Remote Desktop to download desk.rdp apk.
Console
UUID: UUID of the VM. The UUID uniquely identifies a VM.
VM State: State of the VM.
Host IP: IP address of the host where the VM resides.
VNC Port: VNC port number for remotely logging in to the VM.
Webpage: Window for accessing the VM on a Web page.
Remote Desktop
MAC: MAC address of the VM.
