Manage VM backup files
VM backup file management includes the following topics:
Import a VM backup file
  1. From the left navigation pane, select Data Center >Virtualization > Cluster name > Host name > VM name.
  1. Click the Backup Management tab.
  1. Click Import.
  1. Select a recovery mode, backup directory, and temp directory, and then click OK.
Delete a VM backup file
For CBT backup or common backup, the incremental and differential backup files of the most recent backup chain in a backup directory cannot be deleted.
  1. Click Import.
  1. Click Delete in the Actions column for the backup file you want to delete.
  1. Click OK.
View the backup history of a VM
