Perform this task to view the applications, processes, and services running on a VM, and view information about each process, such as username, process ID, process name, CPU usage, and memory usage.
The VM is in running state.
The VM has installed an OS and CAStools, and the OS is compatible with CAStools.
During an online VM migration, monitoring information such as CPU usage and memory usage might not be accurate.
From the left navigation pane, select Data Center >Virtualization > Cluster name > Host name > VM name.
Click the Process Monitoring tab.
Username: Username for the process.
PID: Unique process ID.
Process Name: Name of a program, process, or service.
CPU Usage: CPU usage of the process.
Memory Usage: Memory usage of the process.
