View performance statistics for a VM
Perform this task to view the following information about a VM: CPU usage, memory usage, I/O throughput statistics, network throughput statistics, disk I/O delay, disk request statistics, CPU frequency, disk usage, number of connections, and partition usage. Viewing partition usage is not supported by ARM hosts. If the VM is configured with vGPUs, you can also view the following information about a VM: GPU/vGPU usage, GPU/vGPU video memory usage, GPU/vGPU encoding rate, and GPU/vGPU decoding rate.
  1. From the left navigation pane, select Data Center >Virtualization > Cluster name > Host name > VM name.
  1. Click the Performance Monitoring tab.
  1. Select the search date from the date box under the Performance Monitoring tab as required. By default, the system displays the trend of each metric over the last 30 minutes.
