Delete a VM
  1. From the left navigation pane, perform one of the following selections:
  1. Click the VMs tab.
  1. To delete a VM, do the following:
  1. Click More for the VM you want to delete.
  1. Click Delete, and then select a deletion mode.
  1. Click OK. If you select Delete Disk File, you must enter the password of the current administrator and select I am fully aware of the impacts of this operation in addition to clicking OK.
  1. To delete VMs in bulk, do the following:
  1. Select one or multiple VMs that you want to delete.
  1. Click Bulk Operation.
