Manage VM snapshots
A snapshot is a replica of a VM as it was at the moment when you take the snapshot. Snapshot is a temporary disaster recovery solution. If the image file of a VM is corrupted or deleted by mistake, the snapshot data will also be lost. As a best practice, back up VMs if VM backup data is needed in the long run.
Application scenarios
Snapshots can be used for VM recovery when application software and VM OS incompatibility occur because of new application software installation, VM OS upgrade, or application software upgrade.
As a best practice to avoid VM restoration failure, do not edit VM settings during the snapshot creation process.
Create a snapshot
  1. From the left navigation pane, select Data Center >Virtualization > Cluster name > Host name > VM name.
  1. Click Snapshot Management.
  1. Click Add.
  1. Enter a name and description for the snapshot, and then configure the state of memory snapshot.
  1. Click OK.
Restore a VM by using a snapshot
  1. Select the snapshot you want to restore, and then click Restore.
  1. Click OK.
Delete a snapshot
·          After you delete snapshots for the cloud desktops in a manual desktop pool, you cannot restore the cloud desktops from the snapshots. Make sure you are fully aware of the impacts of this operation.
·          If you delete the snapshot for a VM and software deployment is in progress for the software library template created based on the VM, software deployment will become abnormal. Make sure you are fully aware of the impacts of this operation.
  1. Select the snapshot you want to delete, and then click Delete.
  1. Click OK.
