Clone a VM as a template
Before cloning a VM as a template, make sure a template storage path has been configured. For more information about template storage, see "Image pools."
  1. From the left navigation pane, select Data Center >Virtualization > Cluster name > Host name > VM name.
  1. Click the Clone to Template tab.
  1. Enter the template name and description, and then select a directory to store the template.
  1. Click OK.
