Perform this task to display detailed host information, top 5 VMs by CPU or memory usage, CPU and memory usage of hosts, and network throughput.
For the modifications to be displayed on the host overview page, reconnect Space Console to the host after you modify the CPU or memory resources of a host.
From the left navigation pane, select Data Center >Virtualization > Cluster name > Host name.
Click the Summary tab.
IP: IP address of the host.
State: Current state of the host.
iLO: IP address used to access the iLO management platform. .ARM hosts do not support displaying iLO address information.
Host Model: Host model. ARM hosts do not support displaying host model information.
Version: CVK version of the host.
CPUs: Total CPU cores of the host.
CPU Model: CPU model.
CPU Frequency: CPU frequency.
Memory: Memory size of the host.
Free Memory: Available memory size of the host.
VMs: Number of VMs on the host, including VMs in running state and VMs in shutdown state.
Local Storage: Disk size of the host.
Available Storage: Available disk size of the host.
Host Time: System time of the host.
Uptime: Uptime of the host.
CPU Overcommit: Host CPU usage, which is the ratio between the VM CPUs and the host CPUs.
Memory Overcommit: Host memory usage, which is the ratio between the VM memory and the host memory.
Storage Usage: Local storage usage.
Resource Usage: CPU usage and memory usage of the host.
Network Throughput: Network throughput in Mbps for the last five minutes. The horizontal axis represents time, and the vertical axis represents throughput.
Top 5 VMs by CPU Usage: Aliases and doughnut charts of the five VMs with the highest CPU usage values on the host.
