Import a VM to a host
Perform this task to import or restore a VM from a VM backup file. You can import VMs from a local directory or from a remote server through FTP or SSH/SCP.
  1. From the left navigation pane, select Data Center > Virtualization > Cluster name > Host name.
  1. Click Import VMs.
  1. Perform the following tasks, and then click Next:
  1. Configure VM and backup time settings, and then click Finish.
