From the left navigation pane, select Data Center > Virtualization.
Click Backup Policies.
Click Enable or Disable for a backup policy.
Click OK.
Click Edit for a backup policy.
Edit the parameters as described in "Parameters," and then click OK.
Click Delete for a backup policy.
Click OK.
Select a backup policy, and then click the VMs Using the Backup Policy tab.
Click Delete for a VM.
Click OK.
Select a backup policy, and then click the Disks Using the Backup Policy tab.
Click Delete for a disk.
Click OK.
