The following information describes the tasks to manage a VOI desktop pool. You can manage a VOI desktop pool from multiple pages. The following tasks are performed from the desktop pool details page.
A VOI client does not download the desktop image newly bound to a desktop pool if the MD5 checksum for the desktop image is the same as that for a desktop image saved on the local endpoint. Two image files are identical if they have the same MD5 checksum. |
From the left navigation pane, select Desktop Pools & Groups.
Click the Desktop Pools tab.
Click the name of a VOI desktop pool.
Click Edit on the toolbar above the tabs.
Edit the desktop pool configuration, and then click Finish.
Click Delete on the toolbar above the tabs.
In the dialog box that opens, click OK.
With this feature enabled for a desktop pool, desktops in the desktop pool will automatically install the drivers on the Applications > Application Center > Drivers page and applications on the Applications > Application Center > App Store page if users open the app store on the desktops.
Enable or disable automatic software driver installation:
To enable or disable automatic software driver installation for all desktops in the desktop pool: Click More on the toolbar above the tabs, select Auto Software Driver Installation, and then select Enable or Disable. In the dialog box that open, click OK.
To enable or disable automatic software driver installation for specific desktops in the desktop pool: Click the VOI Client List tab, select one or multiple desktops, click More on top of the desktop list, select Auto Software Driver Installation, and then select Enable or Disable. In the dialog box that open, click OK.
This task is used for enabling or disabling restoration point creation for desktops in a desktop pool. In restoration point creation mode, a desktop uses the point of time before restoration point creation is disabled as the desktop restoration point. If you configure Restoration Mode as Full Restore or System Restore , a desktop will be restored to the restoration point after it restarts.
Perform the following tasks:
To enable or disable restoration point creation for all desktops in the desktop pool: Click More on the toolbar above the tabs. Select Create Restoration Point, select On or Off, and then click OK. After you click OK to confirm restoration point creation, endpoints in the desktop pool will be restarted immediately and enter the restoration point creation mode. If you click Cancel, you must restart the endpoints manually to enter the restoration point creation mode.
To enable or disable restoration point creation for specific desktops in the desktop pool: Click the VOI Client List tab. Select one or multiple clients, and then click More on the on top of the client list. Select Create Restoration Point, select On or Off, and then click OK. After you click OK to confirm restoration point creation, the related endpoints will be restarted immediately and enter the restoration point creation mode. If you click Cancel, you must restart the endpoints manually to enter the restoration point creation mode.
To help an online VOI desktop user resolve desktop issues, you can access that desktop from its console.
Click Console in the Actions column for a desktop.
Perform the following operations as needed in the console:
Start VOI clients:
To start multiple clients, select the target clients from the client list, click More on top of the list, and then select Start. In the dialog box that opens, click OK.
To start a client, click Start in the Actions column for that client. In the dialog box that opens, click OK.
Shut down VOI clients:
To shut down multiple clients, select the target clients from the client list, click More on top of the list, and then select Shut Down. In the dialog box that opens, click OK.
To shut down a client, click Shut Down in the Actions column for that client. In the dialog box that opens, click OK.
Restart VOI clients:
To restart multiple clients, select the target clients from the client list, click More on top of the list, and then select Restart. In the dialog box that opens, click OK.
To restart a client, click More in the Actions column for that client, and then select Restart. In the dialog box that opens, click OK.
Remove VOI clients:
To remove multiple clients, select the target clients from the client list, click More on top of the list, and then select Remove All. In the dialog box that opens, select I am fully aware of the impacts of this operation, enter the administrator password, and then click OK.
To remove a client, click More in the Actions column for that client, and then select Remove. In the dialog box that opens, select I am fully aware of the impacts of this operation, enter the administrator password, and then click OK.
You can configure desktop monitoring settings on a per-client basis. To view desktop summary and performance monitoring data for a VOI client on its details page, you must enable the client to report monitoring data.
Click More in the Actions column for a client, and then select Set Monitor.
In the dialog box that opens, configure desktop monitoring settings:
To view summary and performance data about the desktop, enable it to report data, set the report interval, and then click OK.
To disable the system from displaying summary and performance data about the desktop, disable it from reporting data, and then click OK.
The system displays desktop summary and performance monitoring data for a VOI client if you enable that client to report monitoring data. To remove history desktop monitoring data for that client and view only new monitoring data, perform this task.
Select one or multiple clients from the client list, click More on top of the list, and then select Clear Monitoring Data.
Perform this task to collect Agent logs from running desktops with VoiAgent installed.
Click More in the Actions column for a VOI client, and then select Collect Logs.
In the client list, click the name of a client.
The client details page opens. On the page, you can obtain basic information, summary data, performance data, and process data about the client. On the page, you can perform various client operations, including startup, restart, shutdown, removal from the desktop pool, and monitoring setup.
To view desktop summary and performance data for a VOI client, you must enable that VOI client to report monitoring data. |
