Deploy a VDI desktop pool
After you create a VDI desktop pool, you can deploy desktops in the desktop pool and authorize users and endpoints to use the desktops deployed in the pool. You can access the VDI desktop pool details page by using one of the following methods:
Bulk deploy desktops
Perform this task to deploy desktops depending on the business requirements.
When bulk deploying desktops running UOS or Kylin operating systems, enable Boot After Deploy, and assign these desktops to users 2 minutes after the deployment is completed. If you fail to do so, login failure occurs when the users perform SSO login.
  1. From the left navigation pane, select Desktop Pools & Groups.
  1. Click the Desktop Pools tab.
  1. Select a desktop pool in the desktop pool list, and then click Bulk Deploy.
  1. Configure basic deployment settings, and then click Next: Configure NIC.
  1. Configure the network settings, and then click Next: Confirm Configuration.
  1. Verify that the deployment configuration is correct, and then click Finish.
Basic deployment settings
Network settings
Preauthorize users/OUs to use the desktop pool
To automatically assign idle desktops to users when they log in to their VDI clients, add their usernames, endpoints, or OUs to the preauthorization list.
If a VDI desktop pool is for endpoint users, authorization is performed on a per-endpoint basis. Users can access the desktops in the VDI desktop pool from preauthorized endpoints, without providing user account information.
·          You can manage policies for desktop pools, users, endpoints, or OUs on the policy group management page. For more information, see "Policy groups."
·          You can perform only preauthorization for a shared desktop pool. A shared desktop pool is not applicable to endpoint users.
·          To avoid errors, do not add teacher users or user groups, or student users or user groups to the preauthorization list in an office and education hybrid scenario.
·          To avoid errors, do not add endpoints or endpoint groups with Learningspace clients installed to the preauthorization list in an office and education hybrid scenario.
·          In a desktop pool for endpoint users, you can add only endpoints or endpoint groups whose authentication mode is endpoint authentication to the preauthorization list.
·          When you add a parent OU and a child OU to the preauthorization list simultaneously and select different authorization policies for them, the child OU uses its own authorization policy. The authorization policy of the parent OU does not take effect on the child OU.
·          For a shared desktop pool or physical host desktop pool, make sure the password of each user meets the password complexity requirements of the WinServer operating system. A user cannot connect to a desktop with an invalid password. A password must be at least 7-character long and contain at least three of the following character types: digits, uppercase letters, lowercase letters, and special characters.
  1. Select a desktop pool in the desktop pool list, and then click Preauthorize.
  1. Add users, user groups, and OUs to the preauthorization list:
To add users to the preauthorization list:
  1. Click Select Users.
  1. Select one or multiple users, and then click OK.
To add user groups to the preauthorization list:
  1. Click Select User Groups.
  1. Select one or multiple user groups, and then click OK.
To add OUs for domain users to the preauthorization list:
  1. Click Select OU.
  1. Select one or multiple OUs, and then click OK.
  1. To remove preauthorized objects from the preauthorization list:
  1. Select one or multiple preauthorized objects, and then click Delete Authorizations.
  1. In the dialog box that opens, click OK.
The users or endpoints will be unable to access any cloud desktops in the desktop pool.
  1. To recover authorizations:
  1. Click Recover Authorizations.
  1. Select deleted preauthorized objects, and then click OK.
Authorize a user or endpoint to use a desktop
·          You can configure user and endpoint authorizations, delete authorizations, and recover authorizations from the desktop list only for desktops in a static desktop pool.
·          To avoid errors, do not authorize teacher users or student users to use the desktops in an office and education hybrid scenario.
·          To avoid errors, do not authorize endpoints with Learningspace clients installed to use the desktops in an office and education hybrid scenario.
·          In a desktop pool for endpoint users, you can configure only endpoints whose authentication mode is endpoint authentication to use the desktops.
Perform this task to manually authorize a user or endpoint to use a desktop.
  1. Click the name of the target VDI desktop pool in the desktop pool list.
  1. Click the Desktops tab, and then perform the following tasks:
In the Authorized User Login Name or Authorized Endpoint column for a desktop, click the Search to Add icon. In the dialog box that opens, select a user or endpoint, and then click OK.
Click More in the Actions column for a desktop, and then select Recover Authorizations. Select deleted authorization objects, and then click OK.
