Add local user groups
Use one of the following methods to add local user groups:
Create a local user group
  1. From the left navigation pane, select Users > Local Users.
  1. On the User Groups tab of the Overview page, click Create.
  1. In the dialog box that opens, configure user group parameters.
  1. Click OK.
Manage grade levels (education scenario)
In the current software version, ARM hosts do not support grade level management.
  1. Click Manage Grade Levels in the upper-right corner of the page.
  1. Click Create.
  1. In the dialog box that opens, configure the grade level name and the lower-level grade.
  1. Click OK.
The new grade level is displayed in the Manage Grade Levels dialog box, and you can delete an existing grade level.
Import local user groups
  1. On the User Groups tab of the Overview page, click More, and then click Import.
  1. Click Download Template and add local user group information to the downloaded template file.
  1. Upload the file back to the Space Console and configure other import parameters.
  1. Click Next.
  1. Verify that the configuration is correct.
  1. Click OK.
