Manage a VDI course
For a course that has not been published yet, you can publish, open console for, close, copy, create snapshot, download, edit, backup, or delete the course. For a course that has been published, you can cancel publishing, copy, create snapshot, download, backup, or delete the course.
Do not publish, cancel publishing, copy, or back up courses during class.
Publish a VDI course
Only a published course can be used in classes. You must close the course before publishing it.
When you publish a course, you can select a storage path created on the Data Center > Teaching Storage > GlusterFS Settings page or Data Center > Teaching Storage > Course Storage Pool Settings page.
  1. From the left navigation pane, select Images.
  1. Click the Courses tab.
  1. Click  in the tile for a course.
  1. Select a storage path for the course, and click OK. As a best practice, select a GlusterFS storage path. The course will be published after a period of time.
Cancel publishing a VDI course
  1. In the dialog box that opens, click OK. The published course will be canceled after a period of time.
Open the VDI course console
You can open the console for only a course that has not been published yet.
Close a VDI course
You can close only a running course that has not been published yet.
Start a VDI course
You can start only a closed course that has not been published yet.
Copy a VDI course
You can copy both published and unpublished courses. The courses created from the copies are in unpublished state.
  1. Specify the new course name, and specify whether to enable exam mode as needed.
  1. Click OK.
Create a VDI course snapshot
You can create snapshots for both published and unpublished courses. Taking snapshots is a temporary disaster recovery solution. When the image files of VMs are damaged or deleted by mistake, snapshot data will also get lost. As a best practice for long-term use, back up VMs.
  1. Click Create. In the dialog box that opens, enter the snapshot name and click OK.
  1. To restore a snapshot for the course, select the snapshot and then click Restore. To delete the snapshot, select the snapshot and then click Delete.
Download a VDI course
You can download both published and unpublished courses.
Edit a VDI course
You can edit only a course that has not been published yet.
  1. In the dialog box that opens, edit the settings, and then click OK.
Clear teaching desktops for an exam course
Perform this task to clear teaching desktops for an exam course in the specified classroom after the class is dismissed. This task applies only to exam courses. You can also perform this task on the classroom page, or enable automatic exam desktop cleanup and set a cleanup schedule when creating or editing a classroom.
  1. Select a classroom, and then click OK.
Specify a backup storage pool
This task typically applies to courses in host network isolation scenarios, such as exam courses. Before starting such a class, back up the course to the backup storage pool on each intended host.
  1. Click Backup Storage Pool Settings in the upper right corner of the page.
  1. Click Edit in the Actions column for a host, select the storage path, and then click OK.
Back up a VDI course
Perform this task to back up a VDI course to the specified backup storage pool.
·          Before performing this task, configure the backup storage pool settings.
·          This task applies only to courses that have been published and stored in the GlusterFS storage or shared storage.
  1. Select one or more backup storage pools, and then click Back Up.
Clear backup files for a course
Perform this task to clear backup files for a specific course from the backup storage pool. This task applies to both published and unpublished courses.
  1. Select one or more backup storage pools, and then click Clear.
Delete a VDI course
You can delete both published and unpublished courses.
View detailed information about a VDI course
  1. Click the name of a VDI course to view its information.
  1. To close the dialog box, click OK.
Migrate a VDI course
Perform this task to migrate VDI courses to another storage pool. Before migration, the course must be in an unpublished state.
  1. Click Migrate Course.
  1. In the dialog box that opens, select a course, target cluster, target host, target storage pool, and then click OK.
