Add a VDI course
The system supports adding a VDI course by creating or importing the VDI course. You can use the system image ISO file to create a VDI course, or import a base file to create the course.
Create a VDI course
  1. From the left navigation pane, select Images.
  1. Click the Courses tab.
  1. Click Create.
  1. Select a VDI course type, and complete the basic course settings.
  1. To add a data disk for the course, click Attach Hardware, select Disk, and then set the disk size.  For more information, see "Parameters."
  1. Click Save & Proceed to enter the software installation procedure, and start to "Build a VDI course."
·          Before you create a course, upload the H3C_Learningspace_App-version-win32.zip package and required software to the shared disk from the Images > Shared Software page.
·          On the Images > Shared Software page, you can click Create Folder to create subfolders under the default folder for saving uploaded software and files, and click Upload Files to upload files or software to the subfolders.
·          The management platform supports bulk file upload, resuming file upload, and filtering files by username or user who uploaded a file.
·          During the software installation process, you can click Finish at any time to quit software installation. To continue building the course, click the  icon for the course to open the course console.
·          To use the quiz, score statistics, and game functions, install Chrome browser (Chrome 45 or higher as a best practice) in the course image. For more information, see the teacher client user manual in the education scenario.
Import a VDI course
Perform this task to import a VDI course to Space Console. The imported VDI course image can be edited.
  1. Click Import, select the VDI course type, and upload a base file.
  1. Configure other settings in the same way a VDI course is created. For more information, see "Parameters."
  1. Click Finish.
Use a desktop image to build a course (hybrid office and education scenario)
In the hybrid office and education scenario, the system supports building a VDI course by using a desktop image in the office scenario.
  1. Click Build with Desktop Image.
  1. Select a desktop image in the office scenario, and then configure other settings in the same way a VDI course is created. For more information, see "Parameters."
