Container engine service
·          The container engine service is available only when the container service is enabled. For more information about container configuration, see "Configure container settings."
·          The container engine service requires the role of operator admin. Do not disable this role.
·          ARM host do not support the container engine service.
The cloud container engine consolidates compute, network, and storage, allowing you to create a highly available, scalable Kubernetes cluster. With disaster recovery and autoscaling, the cloud container engine can manage the lifecycle of applications, simplifying cluster management and applications O&M.
The container engine service offers workloads and container clusters.
Clusters
A cluster is a set of compute, storage, and network resources that run containerized applications. Nodes in a cluster include controller nodes and worker nodes. A controller node determines where an application must run. A worker node runs containerized applications. It is managed by the controller node and monitors and reports application status, and manages the application as required by the controller node.
Figure-1 Cluster structure
Workloads
Workload is a concept in Kubernetes. Workloads provide automated and one-key container management capabilities. Workloads in Kubernetes include the following:
Figure-2 Workloads
Other cluster management capabilities
The container engine also provides namespace management, ConfigMap management, service configuration, storage configuration, and autoscaling functions for Kubernetes cluster management and maintenance.
Applications run in a Kubernetes cluster as containers. Pods are the smallest deployable units of computing that you can create and manage in Kubernetes. A Pod has one or multiple containers running on it. Managing a Kubernetes cluster is actually managing the containers running in it.
Figure-3 Kubernetes capabilities
Service
A service exposes an application running on a set of Pods as a network service. In Kubernetes, each Pod gets its own IP address, but the IP address might change upon a Pod restart. Kubernetes assigns a service an IP address (the cluster IP) to map the service to Pods. To access a container, a user only needs to access the cluster IP, no matter whether Pods change or not.
The following are the service types:
Figure-4 Service architecture
Storage
PersistentVolumes (PVs) and PersistentVolumeClaims (PVCs) in Kubernetes provide storage space for clusters.
Configuration
In Kubernetes, the configuration system contains ConfigMaps and Secrets, allowing you to decouple configuration from your container images to keep containerized applications portable. Additionally, with this configuration system, you can manage and maintain configuration information in a unified manner.
Namespace
Namespaces are a way to isolate applications. Applications in different namespaces cannot access each other.
Autoscaling
When the CPU or memory usage reaches the specified threshold, your cluster scales up automatically for the nodes in the cluster to share load until the number nodes in the cluster reaches the upper limit.
