Appendix A P2V migration compatibility matrixes
Operating system compatibility matrix
OS versions
Remarks
Windows
  • Windows Server 2003
  • Windows Server 2003 SP2 x86/x64
  • Windows Server 2003 R2 SP2 x86/x64
  • Windows Server 2008
  • Windows Server 2008 SP1 x64
  • Windows Server 2008 SP2 x86
  • Windows Server 2008 R2 SP1 x64
  • Windows Server 2012
  • Windows Server 2012 x64
  • Windows Server 2012 R2 x64
  • Windows Server 2016
  • Windows Server 2016 x64
P2V migration is also compatible with the unlisted versions that belong to a major version in the version list.
P2V migration is incompatible with Windows desktop versions.
Linux
Redhat 4/5/6 32bit
Redhat 4/5/6/7 64bit
Centos 6 32 bit
Centos 6/7 64 bit
Ubuntu 10/12/14 32bit
Ubuntu 16 64bit
NeoKylin (X86) 5.0/6.0/6.5/6.7/V7 64bit
Kylin Server (X86) 3.2/6.7 64bit
RedFlag 5.0 32bit
RedFlag 6.2/6.3/7.0 64bit
RedFlag axws3-64
Suse  10/11 32bit
Suse  10/11/12 64bit
The kernel version must be between 2.6.18 and 4.14.0.
P2V migration is also compatible with customized Linux versions not in the version list as long as they pass POC test, such as the operating systems customized based on the core management suite of Redhat, CentOS, or Ubuntu Linux.
P2V migration is compatible with the Linux operating systems running on both servers and desktops.
Source disk and file system compatibility
Source disk compatibility
Item
Compatibility with migration/disaster recovery
Local disk
Yes
iSCSI/FC LUN
Yes
Multipathed logical volume
Yes
LVM/LVM2 logical volume
Yes
Spanned volume
Yes
NFS/CIFS/Samba network shared directory
No
File system compatibility
Item
Compatibility with standard migration/disaster recovery
Compatibility with fast migration/disaster recovery
EXT2/EXT3/EXT4
Yes
Yes
XFS
Yes
Yes
FAT/FAT32
Yes
Yes
NTFS
Yes
Yes
ReiserFS
Yes
Yes
Raw disk
Yes
No
Source host compatibility
You can migrate physical servers and VMs created by mainstream hypervisors such as VMware and Xen to CAS.
