On UIS Cloud, click Cloud Services on the top navigation bar. On the UIS-Sec portal of UIS Manager Standard Edition, click Network Services on the top navigation bar.
From the left navigation pane, select Network & Security > Firewalls.
Click the Object Groups tab.
Click Create.
Specify the object group name, type, and description.
Click Create.
Click an object group name.
On the Object Details tab, click Create.
Specify object parameters. The object type must match the object group type, and you cannot edit the object type after you create the object.
Click Create.
Create an object group
Type: Specify the object group type. Options include IPv4 Address and Service. The group type defines objects in the group. This field cannot be edited after object group creation.
IPv4 Address: You can create IPv4 address objects in an IPv4 address object group to match the IPv4 address in a packet.
Service: You can create service objects in a service object group to match the upper-layer service in a packet.
Create an object
IPv4 Address: Specify an IPv4 address, subnet IPv4 address, or IPv4 address range, for example, 192.168.1.1, 192.168.1.0/24, or 192.168.1.0-192.168.2.0. If you specify an address range, make sure the end address is higher than the start address.
Protocol: Specify the protocol. Options include TCP, UDP, and ICMP. If you select TCP or UDP, you must also specify the source and destination ports or port ranges, for example 200 or 201-205.
Source Ports: Specify a source port number or source port range. A port number must be in the range of 0 to 65535. If you specify a port range, make sure the start number is smaller than the end number.
