When the number of public IP addresses configured reaches the quota limit, the cloud administrator of UIS Cloud or the system administrator of UIS Manager Standard Edition can increase the public IP quota to meet the usage requirement.
On UIS Cloud, click Cloud O&M on the top navigation bar. On the UIS-Sec portal of UIS Manager Standard Edition, click O&M on the top navigation bar.
From the left navigation pane, select Resource Quotas > Overall Plan.
Click the
icon (UIS Cloud) or the
icon (UIS-Sec portal of UIS Manager Standard Edition) in the Actions column for the plan.
Edit the overall plan information to increase the public IP quota.
Click OK.
AZs: Select the AZs that provide compute and storage resources.
Quota Template: Select a quota template.
Compute/Storage/Network Quotas: Specify the maximum quotas for compute, storage, and network resources. The resources used in services cannot exceed their respective quota.
IP Segments: Specify the IP segments that can be assigned to users.
CIDR: This parameter is for adding an IP segment. It specifies the CIDR for the IP segment.
