This feature is supported by the cloud administrators on the UIS Cloud and the system administrators on the UIS-Sec portal of UIS Manager Standard Edition.
This feature applies to the following resources:
Routers.
Private networks.
vNICs (NICs of cloud hosts).
Public IPs.
Firewalls.
Load balancers.
Load balancer listeners.
Security groups (not supported by the UIS-Sec portal of UIS Manager Standard Edition).
Subnets.
On UIS Cloud, click Cloud O&M on the top navigation bar. On the UIS-Sec portal of UIS Manager Standard Edition, click O&M on the top navigation bar.
From the left navigation pane, select Resource Quotas > Overall Plan.
On UIS Cloud, click the
icon in the Actions column. On the UIS-Sec portal of UIS Manager Standard Edition, click the
icon.
Edit the overall plan. For more information, see "Parameters."
Click OK.
AZs: Select available zones used to provide real compute and storage resources.
Quota Template: Select a quota template. Options include Small, Medium, and Large.
Compute Quotas/Storage Quotas/Network Quotas: Configure the overall plan for the available amount of resources, including compute, storage, and network resources. Cloud resources created or applied for by users cannot exceed the resource upper limit.
IP Ranges: Configure IP addresses that can be assigned to users.
CIDR Address: Specify the CIDR address of IP ranges.
