This section uses a next-generation firewall as an example. The login method for other components is similar. |
On the top navigation bar, click Network Services.
From the left navigation pane, select VDC Topology.
Click the icon of the corresponding NFV value-added security component.
Click Login.
Enter the username and password and then click Login. Both the default username and password are admin.
