You can contact the sales agent to obtain an NFV value-added security component package.
On the top navigation bar, click Cloud Resources.
From the left navigation pane, select Sites > Native Sites.
Click the
icon for the target native site.
On the top navigation bar, click Management.
From the left navigation pane, select Component Management > Component Repository.
Click Upload. Select the target package and then click Start.
Figure-1 Uploading a component package
