Log in to the Web interface of a NFV value-added security component
This section uses a next-generation firewall as an example. The login method for other components is similar.
NFV value-added security components require independent licenses. Purchase the licenses for the corresponding component as needed.
  1. Access the UIS-Sec portal of UIS manager standard edition.
  1. On the top navigation bar, click Network Services.
  1. From the left navigation pane, select VDC Topology.
  1. Click the icon of the corresponding NFV value-added security component.
  1. Click Login.
  1. Enter the username and password and then click Login. Both the default username and password are admin.
You can configure security services for UIS after login.
