Upload an NFV value-added security component package
You can contact the sales agent to obtain an NFV value-added security component package.
  1. On the top navigation bar, click Management.
  1. From the left navigation pane, select Component Management > Component Repository.
Figure-1 Component repository
  1. Click Upload. Select the target package and then click Start.
Figure-2 Uploading component
