(Optional) Configure compute node settings
If the password for the system administrator of the UIS standard edition is changed, you must change the password accordingly on the advanced features page.
Removing a compute node connection will disable the UIS-Sec platform from managing the VMs running on the compute node. Before you perform this operation, verify that the compute node is no longer needed. If you remove a compute node by mistake, incorporate it again and add compute and storage AZs.
  1. On the top navigation bar, click System.
  1. From the left navigation pane, select Advanced Settings > Advanced Features.
  1. Configure the compute node parameters as described in "Parameters."
