Initialize the management node
  1. On the top navigation bar, click Network.
  1. From the left navigation pane, select Advanced Network Management.
  1. Click Initialize Management Node in Standalone Mode.
  1. On the H3C Matrix login page that opens, enter the username and password, and then initialize the management node as required.
Both the username and password are admin by default.
