Change the network mode
After deploying UIS-Sec management component VMs and UIS-Sec gateway component VMs, you can switch the network mode to advanced.
If you no longer use the UIS-Sec management component, enable basic network mode.
  1. On the top navigation bar, click Network.
  1. From the left navigation pane, select Advanced Network Management > Network Mode Management.
Figure-1 Network mode management
  1. Select the advanced network mode, and then configure the parameters.
  1. Click Save.
  1. The configuration takes effect at the next login.
