On the top navigation bar, click Network.
From the left navigation pane, select Advanced Network Management.
Click Create Network Bridge vs_gateway.
Click Add.
Figure-1 vSwitches
Set the vSwitch name to vs_gateway, select Service as the network type, enable DPDK in the advanced settings, and then click Next.
Figure-2 Adding vSwitch
