The UIS-Sec management component VM can be deployed only once.
Select only one available host as the destination host when you deploy the UIS-Sec management component VM. The UIS-Sec management component does not support cluster deployment.
Make sure the system storage pool of the UIS-Sec management component VM contains only SSDs, and the VM exclusively uses the disk pool where the system storage pool resides. If you fail to do so, the UIS-Sec management component will become abnormal.
For information about creating storage pools, see UIS basic services configuration. As a best practice, use three 480GB SSDs to set up a disk pool and create a data pool with two replicas for creating a shared storage pool.
On the top navigation bar, click Network.
From the left navigation pane, select Advanced Network Management.
Click Deploy UIS-Sec Management Component Package.
Click the component.uisNet tab.
Click Deploy.
Figure-1 Component management page
Select a component type and a component package, and then click Next.
Select a host for VM deployment, and then click Next.
Specify a management network IP address and gateway address, configure other parameters, and then click Finish. For more information about the parameters, see "Parameters."
After the deployment finishes, the UIS-Sec management component VM will be displayed on the component VM page.
Management Network IP: Specify a management network IP address for a component VM.
Gateway: Specify a gateway address for the management network.
System Storage Pool: Select a shared storage pool that contains only SSDs in exclusive mode.
Management Network Port Profile: Select a port profile for the management network. In the current software version, only VLAN configuration takes effect. For successful deployment, make sure vswitch0, the management networks of UIS Cloud and the UIS-Sec management component, and the management network of the UIS-Sec gateway component have the same VLAN ID.
