Before deploying UIS-Sec, you must upload the UIS-Sec management component package to the component repository. The UIS-Sec management component VM provides the UIS-Sec portal of UIS Manager Standard Edition. UIS-Sec component VMs and value-added NFV security component VMs can be deployed only after the UIS-Sec management component VM is deployed.
To obtain the UIS-Sec management component package, contact the franchiser.
On the top navigation bar, click Network.
From the left navigation pane, select Advanced Network Management.
Click Upload UIS-Sec Management Component Package.
Click Upload.
Click in the dotted box to select the component package file.
Click Start.
Figure-1 Uploading component
