This section describes how to manage and use Web application firewall (WAF) resources on the VDC topology. The following features are available:
View detailed information about a WAF resource.
Log in to a WAF resource.
Delete a WAF resource.
Restart a WAF resource.
Shut down a WAF resource.
Monitor a WAF resource.
Edit service networks associated with a WAF resource.
On UIS Cloud, click Cloud Services on the top navigation bar. On the UIS-Sec portal of UIS Manager Standard Edition, click Network Services on the top navigation bar.
From the left navigation pane, click VDC.
Click the icon of a WAF resource to view detailed information about the WAF resource. For more information, see "Parameters."
UUID: UUID of the WAF resource.
State: State of the WAF resource. Values include Running and Shut Down.
Name: Name of the WAF resource.
Deployment State: Deployment state of the WAF resource. Values include Succeeded and Failed.
Image: Name of the image required for deploying the WAF resource.
IP: IP address of the WAF resource.
DPDK State: Whether DPDK is enabled on the WAF resource.
Network Settings: Management network and service network settings of the WAF resource. Hover the mouse over the area to view detailed information.
Routes: Static routes configured for the WAF resource.
Organization: Organization of the WAF resource.
Click the icon of a WAF resource.
Click Login.
On the page that opens, log in to the WAF resource and configure it.
Click Delete.
Click OK.
Click Restart.
Click OK.
Click More, and then select Shut Down.
Click OK.
Click More, and then select Resource Monitoring.
View the monitored parameters.
Click More, and then select Edit Networks.
Edit the networks associated with the WAF resource.
Perform this task to start a WAF resource that is not running.
Click More, and then select Start.
