ACG resources
This section describes how to manage and use application control gateway (ACG) resources on the VDC topology. You can perform the following tasks:
View detailed information about an ACG resource
  1. On UIS Cloud, click Cloud Services on the top navigation bar. On the UIS-Sec portal of UIS Manager Standard Edition, click Network Services on the top navigation bar.
  1. From the left navigation pane, click VDC.
  1. Click the icon of an ACG resource to view detailed information about the ACG resource. For more information, see "Parameters."
Log in to an ACG resource
  1. Click the icon of an ACG resource.
  1. Click Login.
  1. On the page that opens, log in to the ACG resource and configure it.
Delete an ACG resource
  1. Click Delete.
  1. Click OK.
Restart an ACG resource
  1. Click Restart.
  1. Click OK.
Shut down an ACG resource
  1. Click More, and then select Shut Down.
  1. Click OK.
Monitor an ACG resource
Perform this task to open the Resource Monitoring page of an ACG resource.
  1. Click More, and then select Resource Monitoring.
  1. View the parameters.
Edit service networks associated with an ACG resource
  1. Click More, and then select Edit Networks.
  1. Edit the service networks associated with the ACG resource.
Start an ACG resource
Perform this task to start an ACG resource that is not running.
  1. Click More, and then select Start.
  1. Click OK.
