On UIS Cloud, click Cloud Services on the top navigation bar. On the UIS-Sec portal of UIS Manager Standard Edition, click Network Services on the top navigation bar.
From the left navigation pane, select Network & Security > Firewalls.
Configure the description and rules for the rule set. Click the
icon or
icon to add the selected rules or all rules in the Available rule list to the Selected rule list. Click the
icon or the
icon to remove the selected rules or all rules from the Selected rule list. Move a selected rule up or down to change priority of the rule.
