On UIS Cloud, click Cloud Services on the top navigation bar. On the UIS-Sec portal of UIS Manager Standard Edition, click Network Services on the top navigation bar.
From the left navigation pane, select Network & Security > Firewalls.
Click the Rules tab, and then click Create.
Configure the rule parameters as described in "Parameters."
Click Create.
Click Import.
Click Download Template to download a template. Configure the rule parameters in the template as described in "Parameters."
Click Select File to select the template file.
Select the rules to be imported, and then click OK.
Name: Name of the rule.
Match Mode: Packet matching mode of the rule. A firewall filters packets based on the five-tuple information of the packets or an object group.
Action: Action (permit or deny) to be taken on the traffic matching the rule.
Protocol: Matching protocol of the rule. At present, TCP, UDP, and ICMP are supported. If you select ANY, the rule matches all supported protocols.
Source IP: Source IP address of the traffic.
Source Port: Source port of the TCP or UDP connection. This field is available only when the protocol is TCP or UDP.
Destination IP: Destination IP address of the traffic.
Destination Port: Destination port of the TCP or UDP connection. This field is available only when the protocol is TCP or UDP.
