On UIS Cloud, click Cloud Services on the top navigation bar.
On the UIS-Sec portal of UIS Manager Standard Edition, click Network Services on the top navigation bar.
From the left navigation pane, select Network & Security > Routers.
Click the icon in the Actions column for a router.
Edit the router settings as needed.
Click OK.
