· Make sure available firewalls exist before performing this task. To create firewalls, access the Cloud Services > Network & Security > Firewalls page. · A router can be attached to only one firewall. · By default, a firewall denies all traffic. |
On UIS Cloud, click Cloud Services on the top navigation bar.
On the UIS-Sec portal of UIS Manager Standard Edition, click Network Services on the top navigation bar.
From the left navigation pane, select Network & Security > Routers.
