Make sure available IP address pools exist before performing this task. To create IP address pools, access the Cloud Services > Network & Security > Public IP Pools page. |
On UIS Cloud, click Cloud Services on the top navigation bar.
On the UIS-Sec portal of UIS Manager Standard Edition, click Network Services on the top navigation bar.
From the left navigation pane, select Network & Security > Routers.
Select whether to enable SNAT.
SNAT translates the source addresses in packets to the external network to the IP address of the border gateway.
